이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the device upside down and then locate the battery latch near the front of the device.
Continue holding the latch then gently pull the battery out of the device.
Continue holding the latch then gently pull the CD-ROM Drive out of the device.
Press firmly on each end of the speaker cover and slide it to the left.
Remove the six screws from the heatsink using the Philips #1 screwdriver.
Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
Gently grasp the ram on the far end as shown in the picture and then pull up and away from the right side of the computer
Gently grasp the factory installed RAM by grabbing each end as shown in the picture and pull the stick directly up
다른 5명이 해당 안내서를 완성하였습니다.
