소개
The Macintosh 165c can take any any compatible RAM chip up to 4 MB. RAM can be upgraded to a maximum of 14 MB through the PSRAM chip.
필요한 것
Orient the computer so the battery is facing you.
Slide the gray plastic battery cover to the right.
Orient the computer right side up with the rear facing you.
Open the Input/Output (I/O) door.
Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
Lift the lower case to remove it.
Locate and lift ram card directly up until connector releases.
Move the card back and forth gently if the connector does not release immediately.
