주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Macintosh PowerBook 165c Trackball Replacement
필요한 것
    1. Macintosh PowerBook 165c Trackball Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Orient the computer so the battery is facing you.
      • Slide the gray plastic battery cover to the right.
      댓글 쓰기
    2. Macintosh PowerBook 165c Trackball Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the battery toward yourself until it is fully detached.
      댓글 쓰기
    1. Macintosh PowerBook 165c Trackball Replacement, Input/Output Door: 3 단계, 이미지 1개 중 1개
      • Orient the computer right side up with the rear facing you.
      • Open the Input/Output (I/O) door.
      댓글 쓰기
    2. Macintosh PowerBook 165c Trackball Replacement: 4 단계, 이미지 1개 중 1개
      • Carefully bend the door into an arch until one of the pins releases from its slot.
      • Once one of the pins is free, remove the I/O door from the computer.
      댓글 쓰기
    1. Macintosh PowerBook 165c Trackball Replacement, Lower Case: 5 단계, 이미지 1개 중 1개
      • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
      댓글 쓰기
    2. Macintosh PowerBook 165c Trackball Replacement: 6 단계, 이미지 1개 중 1개
      • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
      • Twist counter clockwise to remove the screw.
      댓글 쓰기
    3. Macintosh PowerBook 165c Trackball Replacement: 7 단계, 이미지 1개 중 1개
      • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
      댓글 쓰기
    4. Macintosh PowerBook 165c Trackball Replacement: 8 단계, 이미지 2개 중 1개 Macintosh PowerBook 165c Trackball Replacement: 8 단계, 이미지 2개 중 2개
      • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
      • Release the large, gray interconnect ribbon cable just behind the I/O panel.
      • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
      댓글 쓰기
    5. Macintosh PowerBook 165c Trackball Replacement: 9 단계, 이미지 2개 중 1개 Macintosh PowerBook 165c Trackball Replacement: 9 단계, 이미지 2개 중 2개
      • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
      • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
      • Lift the lower case to remove it.
      댓글 쓰기
    1. Macintosh PowerBook 165c Trackball Replacement, Trackball: 10 단계, 이미지 2개 중 1개 Macintosh PowerBook 165c Trackball Replacement, Trackball: 10 단계, 이미지 2개 중 2개
      • Locate the trackball assembly. It is in the upper case and can be identified by a green circuit board.
      • Open the white tab fastener by pulling out on each side. and remove the green and silver ribbon cable.
      • Remove the green and silver ribbon cable by gently pulling it away from the opened tab fastener.
      댓글 쓰기
    2. Macintosh PowerBook 165c Trackball Replacement: 11 단계, 이미지 1개 중 1개
      • Use a T8 torx screwdriver to remove the six, 6.8mm long screws from the top of the green circuit board.
      댓글 쓰기
    3. Macintosh PowerBook 165c Trackball Replacement: 12 단계, 이미지 1개 중 1개
      • Remove all four components of the trackball assembly by lifting upward.
      • The four components of the trackball assembly should include: the green circuit board, a metal support, the track ball, and the casing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
John
회원 가입일: 10/12/11
88 평판
안내서 4개를 작성함
Cal Poly, Team 6-3, Regan Fall 2011 Cal Poly, Team 6-3, Regan Fall 2011 회원
CPSU-REGAN-F11S6G3
4 회원들
안내서 95개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 32
전체 시간: 1,780
