주요 콘텐츠로 건너뛰기
Macintosh PowerBook 165c Trackball Replacement
필요한 것
  1. Macintosh PowerBook 165c Trackball Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
  2. Macintosh PowerBook 165c Trackball Replacement: 2 단계, 이미지 1/1
    • Pull the battery toward yourself until it is fully detached.
  3. Macintosh PowerBook 165c Trackball Replacement, Input/Output Door: 3 단계, 이미지 1/1
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
  4. Macintosh PowerBook 165c Trackball Replacement: 4 단계, 이미지 1/1
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
  5. Macintosh PowerBook 165c Trackball Replacement, Lower Case: 5 단계, 이미지 1/1
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
  6. Macintosh PowerBook 165c Trackball Replacement: 6 단계, 이미지 1/1
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
  7. Macintosh PowerBook 165c Trackball Replacement: 7 단계, 이미지 1/1
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
  8. Macintosh PowerBook 165c Trackball Replacement: 8 단계, 이미지 1/2 Macintosh PowerBook 165c Trackball Replacement: 8 단계, 이미지 2/2
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
  9. Macintosh PowerBook 165c Trackball Replacement: 9 단계, 이미지 1/2 Macintosh PowerBook 165c Trackball Replacement: 9 단계, 이미지 2/2
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
  10. Macintosh PowerBook 165c Trackball Replacement, Trackball: 10 단계, 이미지 1/2 Macintosh PowerBook 165c Trackball Replacement, Trackball: 10 단계, 이미지 2/2
    • Locate the trackball assembly. It is in the upper case and can be identified by a green circuit board.
    • Open the white tab fastener by pulling out on each side. and remove the green and silver ribbon cable.
    • Remove the green and silver ribbon cable by gently pulling it away from the opened tab fastener.
  11. Macintosh PowerBook 165c Trackball Replacement: 11 단계, 이미지 1/1
    • Use a T8 torx screwdriver to remove the six, 6.8mm long screws from the top of the green circuit board.
  12. Macintosh PowerBook 165c Trackball Replacement: 12 단계, 이미지 1/1
    • Remove all four components of the trackball assembly by lifting upward.
    • The four components of the trackball assembly should include: the green circuit board, a metal support, the track ball, and the casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
John
회원 가입일: 10/12/11
88 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-3, Regan Fall 2011 Cal Poly, Team 6-3, Regan Fall 2011 회원
CPSU-REGAN-F11S6G3
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 13
전체 시간: 1,241
