주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Macintosh Powerbook 5300cs Trackpad Replacement
필요한 것
  1. Macintosh Powerbook 5300cs Trackpad Replacement, Battery: 1 단계, 이미지 1/1
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs Trackpad Replacement: 2 단계, 이미지 1/1
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
  3. Macintosh Powerbook 5300cs Trackpad Replacement, Keyboard: 3 단계, 이미지 1/1
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  4. Macintosh Powerbook 5300cs Trackpad Replacement: 4 단계, 이미지 1/2 Macintosh Powerbook 5300cs Trackpad Replacement: 4 단계, 이미지 2/2
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
  5. Macintosh Powerbook 5300cs Trackpad Replacement: 5 단계, 이미지 1/3 Macintosh Powerbook 5300cs Trackpad Replacement: 5 단계, 이미지 2/3 Macintosh Powerbook 5300cs Trackpad Replacement: 5 단계, 이미지 3/3
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
  6. Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: 6 단계, 이미지 1/3 Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: 6 단계, 이미지 2/3 Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: 6 단계, 이미지 3/3
    • Remove the front plastic panel of the laptop by carefully lifting it up.
  7. Macintosh Powerbook 5300cs Trackpad Replacement: 7 단계, 이미지 1/1
    • Remove the orange stripped ribbon that connects the trackpad to the rest of the laptop by carefully pulling up.
  8. Macintosh Powerbook 5300cs Trackpad Replacement: 8 단계, 이미지 1/2 Macintosh Powerbook 5300cs Trackpad Replacement: 8 단계, 이미지 2/2
    • With a Torx #9 screwdriver, remove the two .20 in. screws circled in red that are holding the trackpad in place.
    • Then disconnect the ribbon highlighted with the red rectangle connecting the trackpad to the laptop.
  9. Macintosh Powerbook 5300cs Trackpad Replacement: 9 단계, 이미지 1/1
    • The trackpad can now be removed from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ronan
회원 가입일: 10/10/11
63 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-1, Regan Fall 2011 Cal Poly, Team 6-1, Regan Fall 2011 회원
CPSU-REGAN-F11S6G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,016
