주요 콘텐츠로 건너뛰기
Mad Catz Dual Force 2 Pro Buttons Replacement
필요한 것
  1. Mad Catz Dual Force 2 Pro Buttons Replacement, Buttons: 1 단계, 이미지 1/1
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Buttons Replacement: 2 단계, 이미지 1/1
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Buttons Replacement: 3 단계, 이미지 1/1
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Buttons Replacement: 4 단계, 이미지 1/2 Mad Catz Dual Force 2 Pro Buttons Replacement: 4 단계, 이미지 2/2
    • Lift the closest circuit board away from the motherboard.
    • Be sure you do not tear the ribbon connecting the smaller circuit board to the motherboard.
  5. Mad Catz Dual Force 2 Pro Buttons Replacement: 5 단계, 이미지 1/1
    • Remove the two 7 mm Philip screws on the larger circuit board.
  6. Mad Catz Dual Force 2 Pro Buttons Replacement: 6 단계, 이미지 1/2 Mad Catz Dual Force 2 Pro Buttons Replacement: 6 단계, 이미지 2/2
    • Remove the motherboard assembly from the cover.
  7. Mad Catz Dual Force 2 Pro Buttons Replacement: 7 단계, 이미지 1/1
    • Lift out any of the plastic buttons you want to replace.
결론
Alexander Coyne
회원 가입일: 01/11/15
658 평판
안내서 5개 작성하였습니다
USF Tampa, Team 7-2, Remmell Winter 2015 USF Tampa, Team 7-2, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 455
