주요 콘텐츠로 건너뛰기
Mad Catz Dual Force 2 Pro Vibration Motors Replacement
필요한 것
  1. Mad Catz Dual Force 2 Pro Vibration Motors Replacement, Remove Cover: 1 단계, 이미지 1/1
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: 2 단계, 이미지 1/1
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: 3 단계, 이미지 1/1
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: 4 단계, 이미지 1/2 Mad Catz Dual Force 2 Pro Vibration Motors Replacement: 4 단계, 이미지 2/2
    • Grip the sides of the motor you wish to replace and lift up.
    • Be careful not to tear the wires that connect the motors to the motherboard.
  5. Mad Catz Dual Force 2 Pro Vibration Motors Replacement, Remove the Screw: 5 단계, 이미지 1/1
    • Use a soldering iron to de-solder both vibration motor wires from the motherboard.
    • If you do not know how to solder, see the soldering guide for instructions.
    • The positive (red) wire connects nearest the edge of the motherboard.
    • When soldering on circuit boards, be sure not to overheat the connection as permanent damage may result.
  6. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: 6 단계, 이미지 1/1
    • If needed, repeat the last two steps for the other vibration motors.
결론
Alexander Coyne
회원 가입일: 01/11/15
658 평판
안내서 5개 작성하였습니다
USF Tampa, Team 7-2, Remmell Winter 2015 USF Tampa, Team 7-2, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 321
