소개
Needing a guide on how to fix a specific type of controller is very hard to come by nowadays. Luckily this guide can help you fix a damaged Mad Catz FightPad PRO controller joystick or customize your controller just for fun.
필요한 것
Remove the single 6 mm screw on the back shell of the controller using a Phillips #00 screwdriver.
Remove the eight 6 mm screws from the motherboard using a Phillips #00 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
