주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement
필요한 것
  1. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement, Outer Casing: 1 단계, 이미지 1개 중 1개
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement: 3 단계, 이미지 1개 중 1개
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement, Five Way Toggle Switch: 4 단계, 이미지 1개 중 1개
    • Look for the toggle switch component on the inside of the guitar. The component rests in a black, circular holder that is positioned perpendicular relative to the inside of the front of the guitar.
    • Unscrew the two black, vertical, 5 mm philips head screws holding the part in place using a size J1 screwdriver.
  5. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the entire component out in a vertical motion.
  6. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement: 6 단계, 이미지 1개 중 1개
    • Follow the wires from the component to the main circuit board. Unplug the toggle switch component from the main board.
    • Plug in your replacement toggle switch hardware.
결론
To reassemble your device, follow these instructions in reverse orde
작성자
3다른 기여자 명과 함께
Hollynn Ricker
회원 가입일: 09/28/16
451 평판
안내서 2개를 작성함
USF Tampa, Team 1-1, Cagle Fall 2016 USF Tampa, Team 1-1, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G1
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 27
전체 시간: 1,681
