주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mad Catz Rock Band 4 Wireless Fender Power Button Replacement
필요한 것
  1. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement, Outer Casing: 1 단계, 이미지 1개 중 1개
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: 3 단계, 이미지 1개 중 1개
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement, Power Button: 4 단계, 이미지 1개 중 1개
    • Using a size J1 philips head screwdriver, remove the two black 5 mm screws (circled in red) from the back of the power button component. You can identify this by the code J5-B on the component.
  5. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: 5 단계, 이미지 1개 중 1개
    • Using your hands, lift the small, rectangular circuit board off and follow the connecting cords to the main circuit board.
    • Unplug the cord connected to the battery component from the main circuit board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Catherine Lintner
회원 가입일: 09/21/16
581 평판
안내서 4개를 작성함
USF Tampa, Team 1-1, Cagle Fall 2016 USF Tampa, Team 1-1, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G1
4 회원들
안내서 6개를 작성함
1가이드 댓글
I need two Rock Band 4 Home Button/Bluetooth Replacement Parts, where to locate??
My name is Robert.
Thank you in regards to whom can assist
Robert Houser Jr - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 27
전체 시간: 3,635
