이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use tweezers to completely remove the sticker from the rear of controller.
Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
Use the plastic opening tool to pry the two cases apart.
Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
다른 한 분이 해당 안내서를 완성하였습니다.
