주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Mad Catz Street Fighter IV FightPad Directional Pad Replacement
필요한 것
  1. Mad Catz Street Fighter IV FightPad Directional Pad Replacement, Rear and Side Case: 1 단계, 이미지 1/1
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 2 단계, 이미지 1/1
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 3 단계, 이미지 1/2 Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 4 단계, 이미지 1/2 Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 4 단계, 이미지 2/2
    • Remove the two rubber side grips.
  5. Mad Catz Street Fighter IV FightPad Directional Pad Replacement, RS-DP-LS Switch: 5 단계, 이미지 1/2 Mad Catz Street Fighter IV FightPad Directional Pad Replacement, RS-DP-LS Switch: 5 단계, 이미지 2/2
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
  6. Mad Catz Street Fighter IV FightPad Directional Pad Replacement, Circuit Board: 6 단계, 이미지 1/1
    • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  7. Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 7 단계, 이미지 1/3 Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 7 단계, 이미지 2/3 Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 7 단계, 이미지 3/3
    • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
    • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
    • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
  8. Mad Catz Street Fighter IV FightPad Directional Pad Replacement, Directional Pad: 8 단계, 이미지 1/1
    • Use tweezers to remove the rubber part of the directional pad.
  9. Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 9 단계, 이미지 1/2 Mad Catz Street Fighter IV FightPad Directional Pad Replacement: 9 단계, 이미지 2/2
    • Insert a new directional pad over the original directional pad's location.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jefferson
회원 가입일: 09/26/12
78 평판
안내서 1개 작성함
Cal Poly, Team 1-7, Propen Fall 2012 Cal Poly, Team 1-7, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G7
4 회원들
안내서 14개 작성하였습니다
댓글 2개
mi spiegate l'utilita di questa guida?vendere forse le pinzette e tutte le altre stronzatine che servono per riparare il fightpad?quando invece il pezzo più importante cioè il gommino non lo vendete....fate pena
auredo1988 - 답글
Hi I don't speak Italian but I think you are asking "what is the purpose of this guide?". We made these as a project for university because I wanted to resolder a wire in this controller that came undone. For good measure we made a guide for each individual part although the real purpose of these guides was for the full disassembly and re soldering.
Eric Devlin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 15
전체 시간: 4,437
