주요 콘텐츠로 건너뛰기
MagLite 4D O-Ring Replacement
  1. MagLite 4D O-Ring Replacement, O-ring: 1 단계, 이미지 1개 중 1개
    • Unscrew the Maglite head.
    • Remember, to unscrew a flashlight head, turn it counterclockwise.
  2. MagLite 4D O-Ring Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the lens.
  3. MagLite 4D O-Ring Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the reflector cone.
  4. MagLite 4D O-Ring Replacement: 4 단계, 이미지 1개 중 1개
    • Examine the O-ring for damage.
    • The O-ring is the black rubber band around the flashlight head.
  5. MagLite 4D O-Ring Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the damaged O-ring.
    • The O-ring is flexible, so it should be easy to pull off. Or, it may fall off if it is broken.
  6. MagLite 4D O-Ring Replacement: 6 단계, 이미지 1개 중 1개
    • Place the new O-ring in the same place as the original.
    • The O-ring is flexible, so simply pull it on gently.
  7. MagLite 4D O-Ring Replacement: 7 단계, 이미지 1개 중 1개
    • Wipe the moisture from the reflector cone with a paper towel or soft cloth.
  8. MagLite 4D O-Ring Replacement: 8 단계, 이미지 1개 중 1개
    • Wipe the moisture from the lens with a paper towel or soft cloth.
  9. MagLite 4D O-Ring Replacement: 9 단계, 이미지 1개 중 1개
    • Replace the reflector cone.
    • Replace the lens.
  10. MagLite 4D O-Ring Replacement: 10 단계, 이미지 1개 중 1개
    • Screw on the Maglite head.
    • Remember, to screw on a flashlight head, turn it clockwise.
  11. MagLite 4D O-Ring Replacement: 11 단계, 이미지 1개 중 1개
    • Test the Maglite by turning it on.
    • If your Maglite turns on, your work is complete!
결론
If your Maglite turns on, it should be ready to go! If your Maglite does not turn on, the next step is to look at the battery compartment. Please see another guide for this step.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Laura Allen
회원 가입일: 10/04/21
223 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 35
전체 시간: 1,230
