소개
You can change the battery by opening up the GPS.
필요한 것
Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
Disconnect the battery connector from the circuit board.
Pry the battery off the circuit board. The adhesive attaching it shouldn't require any other tools.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
