이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
Remove the back cover from the device by separating the back cover along its seam.
Pull the speaker cord, horizontally, by its base, away from the motherboard.
Disconnect the battery connector from the circuit board.
Pry the battery off the circuit board. The adhesive attaching it shouldn't require any other tools.
다른 4명이 해당 안내서를 완성하였습니다.
