주요 콘텐츠로 건너뛰기
Magellan RoadMate 1200 Motherboard Replacement
필요한 것
  1. Magellan RoadMate 1200 Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Magellan RoadMate 1200 Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Magellan RoadMate 1200 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Magellan RoadMate 1200 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  5. Magellan RoadMate 1200 Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Remove the two screws on that are located on opposite sides of the board.
  6. Magellan RoadMate 1200 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Ross Light
회원 가입일: 04/12/10
217 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 5,120
