소개
The speaker can be easily removed from the back cover.
도구
부품
지정된 부품이 없습니다.
Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth.
Once you pull off the back cover, remove the orange piece of tape on the speaker.
Use a Philips #00 screwdriver to remove the 2 screws holding the speaker to the back casing.
거의 끝나갑니다!
결론
