소개
Remove the motherboard from the device for replacement. If the device will not turn on, but the battery is still charged, the motherboard might need to be replaced.
필요한 것
Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
After the back has been removed, locate each of the screws securing the speaker to the inside of the back cover.
Use a Phillips #0 screwdriver to remove the two 3.8mm Phillips #0 screws.
Once the back cover has been removed, lift the power switch from the device.
Now that the screen has been removed from the motherboard, the motherboard is not connected to anything on the device.
Slide the ribbon cable through the opening in the circuit board in order to separate the two.
