주요 콘텐츠로 건너뛰기
Magellan RoadMate 2120T-LM Motherboard Replacement
필요한 것
  1. Magellan RoadMate 2120T-LM Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Magellan RoadMate 2120T-LM Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Magellan RoadMate 2120T-LM Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Turn the GPS over on its backside and remove the six 3 mm Phillips #1 screws.
  2. Magellan RoadMate 2120T-LM Motherboard Replacement: 2 단계, 이미지 1/2 Magellan RoadMate 2120T-LM Motherboard Replacement: 2 단계, 이미지 2/2
    • Pry up on back panel with black spudger
  3. Magellan RoadMate 2120T-LM Motherboard Replacement: 3 단계, 이미지 1/1
    • Disconnect battery and speaker cables from the motherboard at indicated places.
  4. Magellan RoadMate 2120T-LM Motherboard Replacement: 4 단계, 이미지 1/1
    • Use a spudger to remove the battery from the back panel.
    • If at all possible, please try to use a regular nylon spudger before resorting to a metal spudger. Metal spudgers are much sharper, and have the potential to accidentally pierce the battery.
    • There is a strong adhesive holding the battery to the back panel.
    • This step is not a prerequisite for replacement of other components.
  5. Magellan RoadMate 2120T-LM Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Remove the four 3 mm Phillips #1 screws from the motherboard.
    • In the picture three out of four screws have already been removed.
  6. Magellan RoadMate 2120T-LM Motherboard Replacement: 6 단계, 이미지 1/2 Magellan RoadMate 2120T-LM Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove black tape covering connection ribbon for touch-screen
  7. Magellan RoadMate 2120T-LM Motherboard Replacement: 7 단계, 이미지 1/3 Magellan RoadMate 2120T-LM Motherboard Replacement: 7 단계, 이미지 2/3 Magellan RoadMate 2120T-LM Motherboard Replacement: 7 단계, 이미지 3/3
    • Pull up on the brown tab holding down the ribbon.
    • In this picture the brown tab has already been lifted.
    • Lift up on the motherboard and remove it from device.
결론
John Doe
회원 가입일: 01/12/16
503 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 213
