주요 콘텐츠로 건너뛰기
Magellan RoadMate 5236T-LM Back Cover Replacement
필요한 것
  1. Magellan RoadMate 5236T-LM Back Cover Replacement, Back Cover: 1 단계, 이미지 1/3 Magellan RoadMate 5236T-LM Back Cover Replacement, Back Cover: 1 단계, 이미지 2/3 Magellan RoadMate 5236T-LM Back Cover Replacement, Back Cover: 1 단계, 이미지 3/3
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Back Cover Replacement: 2 단계, 이미지 1/3 Magellan RoadMate 5236T-LM Back Cover Replacement: 2 단계, 이미지 2/3 Magellan RoadMate 5236T-LM Back Cover Replacement: 2 단계, 이미지 3/3
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Back Cover Replacement: 3 단계, 이미지 1/2 Magellan RoadMate 5236T-LM Back Cover Replacement: 3 단계, 이미지 2/2
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Megan Scribner
회원 가입일: 10/18/16
315 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-7, Catania Fall 2016 UMass Dartmouth, Team 4-7, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G7
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 178
