주요 콘텐츠로 건너뛰기
Magellan RoadMate 5236T-LM Display Screen Replacement
필요한 것
  1. Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Display Screen Replacement: 2 단계, 이미지 3개 중 1개 Magellan RoadMate 5236T-LM Display Screen Replacement: 2 단계, 이미지 3개 중 2개 Magellan RoadMate 5236T-LM Display Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Display Screen Replacement: 3 단계, 이미지 2개 중 1개 Magellan RoadMate 5236T-LM Display Screen Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: 4 단계, 이미지 3개 중 1개 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: 4 단계, 이미지 3개 중 2개 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: 4 단계, 이미지 3개 중 3개
    • Place the front panel on a flat surface, screen side down.
    • Using a plastic opening tool, apply light lifting pressure to each of the 6 casing clips to release the screen from the plastic casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Megan Scribner
회원 가입일: 10/18/16
324 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-7, Catania Fall 2016 UMass Dartmouth, Team 4-7, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G7
3 회원들
안내서 5개를 작성함
1가이드 댓글
This would have been even a GREATER POST if, would have included the part number for the replacement screen,
But,
Just good information as to how to remove the damaged screen.
1975PINTOBOBSTER
1975PINTOBOBSTER - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 693
