주요 콘텐츠로 건너뛰기
Magellan RoadMate 5250T-LM Motherboard Replacement
필요한 것
  1. Magellan RoadMate 5250T-LM Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Magellan RoadMate 5250T-LM Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Remove all four 5mm screws from the back of the device using a Phillips Head screwdriver size 000.
  2. Magellan RoadMate 5250T-LM Motherboard Replacement: 2 단계, 이미지 1/2 Magellan RoadMate 5250T-LM Motherboard Replacement: 2 단계, 이미지 2/2
    • Open the casing of the device using a plastic spudger.
  3. Magellan RoadMate 5250T-LM Motherboard Replacement: 3 단계, 이미지 1/2 Magellan RoadMate 5250T-LM Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the tape covering the display connector on top of the motherboard.
    • Use a nylon spudger to flip up the black tab on the ZIF connector.
    • Pull the ribbon cable out with tweezers.
    • The ribbon cable may fall out once the tape is removed.
  4. Magellan RoadMate 5250T-LM Motherboard Replacement: 4 단계, 이미지 1/2 Magellan RoadMate 5250T-LM Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the motherboard from the device by unscrewing all three 4mm screws that are connecting it to the casing with a Phillips Head screwdriver size 000.
  5. Magellan RoadMate 5250T-LM Motherboard Replacement: 5 단계, 이미지 1/1
    • Disconnect the original battery from the motherboard and the speaker by desoldering all five wires that attach them to the motherboard.
    • Click here to visit iFixIt's guide on soldering.
결론
Parker Dunaway
회원 가입일: 01/29/16
101 평판
안내서 1개 작성함
University of Alabama, Team 1-7, Sydow campbell Spring 2016 University of Alabama, Team 1-7, Sydow campbell Spring 2016 회원
UA-SYDOW CAMPBELL-S16S1G7
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 300
