소개
This guide will show you how to remove and replace the motherboard inside your Magellan Roadmate 5250T-LM. It would be helpful to know how to solder before attempting this replacement. To remove the motherboard you must desolder it from the battery and speakers. After this, you will need to solder your new motherboard back on to the battery and speakers.
필요한 것
Remove all four 5mm screws from the back of the device using a Phillips Head screwdriver size 000.
거의 끝나갑니다!
결론
