주요 콘텐츠로 건너뛰기
Magellan Roadmate 9055-LM Back Panel Disassembly
필요한 것
  1. Magellan Roadmate 9055-LM Back Panel Disassembly, Magellan Roadmate 9055-LM Back Panel Disassembly: 1 단계, 이미지 1/1
    • Flip your device with back panel facing up.
  2. Magellan Roadmate 9055-LM Back Panel Disassembly: 2 단계, 이미지 1/3 Magellan Roadmate 9055-LM Back Panel Disassembly: 2 단계, 이미지 2/3 Magellan Roadmate 9055-LM Back Panel Disassembly: 2 단계, 이미지 3/3
    • Unscrew four Phillips #0 screws from the back panel.
  3. Magellan Roadmate 9055-LM Back Panel Disassembly: 3 단계, 이미지 1/2 Magellan Roadmate 9055-LM Back Panel Disassembly: 3 단계, 이미지 2/2
    • Unscrew two Phillips #0 screws from the back panel.
  4. Magellan Roadmate 9055-LM Back Panel Disassembly: 4 단계, 이미지 1/2 Magellan Roadmate 9055-LM Back Panel Disassembly: 4 단계, 이미지 2/2
    • Use a plastic opening tool to pop the right side of the panel.
  5. Magellan Roadmate 9055-LM Back Panel Disassembly: 5 단계, 이미지 1/1
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  6. Magellan Roadmate 9055-LM Back Panel Disassembly: 6 단계, 이미지 1/3 Magellan Roadmate 9055-LM Back Panel Disassembly: 6 단계, 이미지 2/3 Magellan Roadmate 9055-LM Back Panel Disassembly: 6 단계, 이미지 3/3
    • Remove the tape.
    • Unplug the cable for the speaker.
  7. Magellan Roadmate 9055-LM Back Panel Disassembly: 7 단계, 이미지 1/3 Magellan Roadmate 9055-LM Back Panel Disassembly: 7 단계, 이미지 2/3 Magellan Roadmate 9055-LM Back Panel Disassembly: 7 단계, 이미지 3/3
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  8. Magellan Roadmate 9055-LM Back Panel Disassembly: 8 단계, 이미지 1/1
    • Place the back panel gently on the table.
결론
YuChe Chang
회원 가입일: 10/18/16
202 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-5, Catania Fall 2016 UMass Dartmouth, Team 1-5, Catania Fall 2016 회원
UMASSD-CATANIA-F16S1G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 210
