주요 콘텐츠로 건너뛰기
Magic Bullet MB1001B Activator Replacement
필요한 것
  1. Magic Bullet MB1001B Activator Replacement, Base Gear: 1 단계, 이미지 3개 중 1개 Magic Bullet MB1001B Activator Replacement, Base Gear: 1 단계, 이미지 3개 중 2개 Magic Bullet MB1001B Activator Replacement, Base Gear: 1 단계, 이미지 3개 중 3개
    • Use pliers to grip the gear inside of the top of the device.
    • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
    • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
    • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
  2. Magic Bullet MB1001B Activator Replacement, Casing: 2 단계, 이미지 1개 중 1개
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  3. Magic Bullet MB1001B Activator Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  4. Magic Bullet MB1001B Activator Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the black base plate.
  5. Magic Bullet MB1001B Activator Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  6. Magic Bullet MB1001B Activator Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the white plastic cable guide.
  7. Magic Bullet MB1001B Activator Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
  8. Magic Bullet MB1001B Activator Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the black base.
  9. Magic Bullet MB1001B Activator Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the three white rubber spacers with the spudger.
  10. Magic Bullet MB1001B Activator Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
  11. Magic Bullet MB1001B Activator Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the motor.
  12. Magic Bullet MB1001B Activator Replacement, Activator: 12 단계, 이미지 2개 중 1개 Magic Bullet MB1001B Activator Replacement, Activator: 12 단계, 이미지 2개 중 2개
    • Wedge a flathead screwdriver in between the casing and white plastic activator.
    • Pry the white plastic activators from the casing as needed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Aubree Duran
회원 가입일: 10/06/15
387 평판
안내서 1개를 작성함
Cal Poly, Team 12-13, Maness Fall 2015 Cal Poly, Team 12-13, Maness Fall 2015 회원
CPSU-MANESS-F15S12G13
4 회원들
안내서 8개를 작성함
4가이드 댓글
You gotta be kidding me?
marcomolinero72 - 답글
Right. Steps on how to fix their faulty machine. And worse. Selling you the tools to do it for only 29.99!
Del - 답글
Where would you get replacement activators or spring beneath these? How much would that cost?
Spartan 1293 - 답글
Oh, my gosh! I’ll just throw this thing away and use my blender!
txberta - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 32
전체 시간: 9,635
