주요 콘텐츠로 건너뛰기
Magic Bullet MB1001B Power Cord Replacement
필요한 것
  1. Magic Bullet MB1001B Power Cord Replacement, Power Cord: 1 단계, 이미지 1/1
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  2. Magic Bullet MB1001B Power Cord Replacement: 2 단계, 이미지 1/1
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  3. Magic Bullet MB1001B Power Cord Replacement: 3 단계, 이미지 1/1
    • Remove the black base plate.
  4. Magic Bullet MB1001B Power Cord Replacement: 4 단계, 이미지 1/1
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  5. Magic Bullet MB1001B Power Cord Replacement: 5 단계, 이미지 1/1
    • Remove the white plastic cable guide.
  6. Magic Bullet MB1001B Power Cord Replacement: 6 단계, 이미지 1/1
    • Remove the two crimp caps from the end of the wires.
    • You will need to purchase new crimp caps and use pliers to crimp the new crimp caps on the connected wires during reassembly.
  7. Magic Bullet MB1001B Power Cord Replacement: 7 단계, 이미지 1/1
    • Separate the black wires of the power cord from the red wires on the Magic Bullet base.
    • Be sure to mark which wires are connected before separating them to ensure that they are properly reconnected during reassembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Bridget Carr
회원 가입일: 10/06/15
266 평판
안내서 1개 작성함
Cal Poly, Team 12-13, Maness Fall 2015 Cal Poly, Team 12-13, Maness Fall 2015 회원
CPSU-MANESS-F15S12G13
4 회원들
안내서 8개 작성하였습니다
댓글 2개
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
virginia.cooke - 답글
Where do we get a new power cord, and if that does not work, what do we do next?
davidcohnkettlebells - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 2,354
