주요 콘텐츠로 건너뛰기
Magic Bullet NutriBullet Curve Base
필요한 것
  1. Magic Bullet NutriBullet Curve Base, Curve Base: 1 단계, 이미지 1/1
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Curve Base: 2 단계, 이미지 1/2 Magic Bullet NutriBullet Curve Base: 2 단계, 이미지 2/2
    • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
  3. Magic Bullet NutriBullet Curve Base: 3 단계, 이미지 1/1
    • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
    • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
  4. Magic Bullet NutriBullet Curve Base: 4 단계, 이미지 1/1
    • Lift the power cord to remove it from the side slot on the curved base.
  5. Magic Bullet NutriBullet Curve Base: 5 단계, 이미지 1/2 Magic Bullet NutriBullet Curve Base: 5 단계, 이미지 2/2
    • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
    • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
  6. Magic Bullet NutriBullet Curve Base: 6 단계, 이미지 1/1
    • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
  7. Magic Bullet NutriBullet Curve Base: 7 단계, 이미지 1/1
    • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Geary Yu
회원 가입일: 01/22/15
1,226 평판
안내서 3개 작성하였습니다
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015 회원
CPSU-MANESS-W15S19G8
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 35
전체 시간: 4,153
