주요 콘텐츠로 건너뛰기
Magic Bullet NutriBullet Outside Casing Replacement
필요한 것
  1. Magic Bullet NutriBullet Outside Casing Replacement, Curve Base: 1 단계, 이미지 1개 중 1개
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Outside Casing Replacement: 2 단계, 이미지 2개 중 1개 Magic Bullet NutriBullet Outside Casing Replacement: 2 단계, 이미지 2개 중 2개
    • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
  3. Magic Bullet NutriBullet Outside Casing Replacement: 3 단계, 이미지 1개 중 1개
    • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
    • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
  4. Magic Bullet NutriBullet Outside Casing Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the power cord to remove it from the side slot on the curved base.
  5. Magic Bullet NutriBullet Outside Casing Replacement: 5 단계, 이미지 2개 중 1개 Magic Bullet NutriBullet Outside Casing Replacement: 5 단계, 이미지 2개 중 2개
    • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
    • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
  6. Magic Bullet NutriBullet Outside Casing Replacement: 6 단계, 이미지 1개 중 1개
    • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
  7. Magic Bullet NutriBullet Outside Casing Replacement: 7 단계, 이미지 1개 중 1개
    • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
  8. Magic Bullet NutriBullet Outside Casing Replacement, Outside Casing: 8 단계, 이미지 1개 중 1개
    • Wiggle the outside casing upward until it separates from the powerbase.
    • Hold the ring at the bottom of the powerbase to receive a better grip.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Angela Wong
회원 가입일: 01/22/15
1,156 평판
안내서 3개를 작성함
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015 회원
CPSU-MANESS-W15S19G8
4 회원들
안내서 13개를 작성함
4가이드 댓글
Ok so what happens after Step 8 of pulling the Nutribullet apart? Did I miss something?? Now I have my Nutribullet in pieces on the benchtop. Now what??
Nicole Corse-Scott - 답글
Same problem. I can't get the drive gear on the top loose which I assume will actual give me access to the wiring. I am guessing it is a pressure fit but I can't get anything under it to pry it loose. If it is a screw attachment don't want to break it. Help.
rjurgena - 답글
So what happens next? What is one suppose to do? Stupid help, I would say
Mary Johnson - 답글
I tried step number 8 and the outside casing still won't slide off. What do I do now?
Euclid Taylor - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 58
전체 시간: 8,150
