주요 콘텐츠로 건너뛰기
Magna Outreach Rear tire Replacement
필요한 것
  1. Magna Outreach Rear tire Replacement, Rear Tire: 1 단계, 이미지 1/1
    • Disconnect the rear brake cable
  2. Magna Outreach Rear tire Replacement: 2 단계, 이미지 1/1
    • Flip the bike over so that it is resting on the seat and handlebars.
    • Use an adjustable wrench to remove the nuts on both sides of the wheel that hold the wheel to the frame.
    • Lift the tire away from the frame and chain.
  3. Magna Outreach Rear tire Replacement: 3 단계, 이미지 1/1
    • Insert one tire lever under the tire and hook it onto a spoke. Insert the other tire lever next to the first and slide it along the rim to remove one side of the tire from the rim.
  4. Magna Outreach Rear tire Replacement: 4 단계, 이미지 1/1
    • Starting at the valve, pull the inner tube out of the gap between the rim and the tire.
  5. Magna Outreach Rear tire Replacement: 5 단계, 이미지 1/1
    • Pull the tire away from the rim.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
West Johnson
회원 가입일: 10/06/14
146 평판
안내서 1개 작성함
USF Tampa, Team 1-14, Donnelly Fall 2014 USF Tampa, Team 1-14, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G14
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 2,468
