주요 콘텐츠로 건너뛰기
Magnavox MWD200F Disk Drive Replacement
필요한 것
  1. Magnavox MWD200F Disk Drive Replacement, Faceplate: 1 단계, 이미지 1/1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. Magnavox MWD200F Disk Drive Replacement: 2 단계, 이미지 1/1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. Magnavox MWD200F Disk Drive Replacement: 3 단계, 이미지 1/1
    • Unclip the three latches on the bottom of the device.
  4. Magnavox MWD200F Disk Drive Replacement: 4 단계, 이미지 1/1
    • Pull the faceplate off.
  5. Magnavox MWD200F Disk Drive Replacement, Disk Drive: 5 단계, 이미지 1/2 Magnavox MWD200F Disk Drive Replacement, Disk Drive: 5 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
  6. Magnavox MWD200F Disk Drive Replacement: 6 단계, 이미지 1/2 Magnavox MWD200F Disk Drive Replacement: 6 단계, 이미지 2/2
    • Use the screwdriver to remove two screws on either side of the silver security bar.
  7. Magnavox MWD200F Disk Drive Replacement: 7 단계, 이미지 1/2 Magnavox MWD200F Disk Drive Replacement: 7 단계, 이미지 2/2
    • Pull out the silver security bar and set aside.
  8. Magnavox MWD200F Disk Drive Replacement: 8 단계, 이미지 1/1
    • Take out the two screws on either side of the green circuit board.
  9. Magnavox MWD200F Disk Drive Replacement: 9 단계, 이미지 1/2 Magnavox MWD200F Disk Drive Replacement: 9 단계, 이미지 2/2
    • Carefully lift the board just enough to remove the disk drive.
  10. Magnavox MWD200F Disk Drive Replacement: 10 단계, 이미지 1/3 Magnavox MWD200F Disk Drive Replacement: 10 단계, 이미지 2/3 Magnavox MWD200F Disk Drive Replacement: 10 단계, 이미지 3/3
    • Remove the two screws at the back of the disk drive.
  11. Magnavox MWD200F Disk Drive Replacement: 11 단계, 이미지 1/2 Magnavox MWD200F Disk Drive Replacement: 11 단계, 이미지 2/2
    • Gently lift the disk drive out of the DVD player.
    • The disk drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
결론
Taryn
회원 가입일: 09/15/11
109 평판
안내서 4개 작성하였습니다
University of Maine, Team 1-2, Diaz Fall 2011 University of Maine, Team 1-2, Diaz Fall 2011 회원
UMAINE-DIAZ-F11S1G2
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 1,494
