주요 콘텐츠로 건너뛰기
Mailbox Flag Replacement
  1. Mailbox Flag Replacement, Flag: 1 단계, 이미지 1/3 Mailbox Flag Replacement, Flag: 1 단계, 이미지 2/3 Mailbox Flag Replacement, Flag: 1 단계, 이미지 3/3
    • Place the bracket into the flag - this will help to secure it to the mailbox.
  2. Mailbox Flag Replacement: 2 단계, 이미지 1/3 Mailbox Flag Replacement: 2 단계, 이미지 2/3 Mailbox Flag Replacement: 2 단계, 이미지 3/3
    • Place the rubber o-ring onto the bracket.
  3. Mailbox Flag Replacement: 3 단계, 이미지 1/3 Mailbox Flag Replacement: 3 단계, 이미지 2/3 Mailbox Flag Replacement: 3 단계, 이미지 3/3
    • Insert the bracket of the assembled flag through the holes on the outside of the mailbox.
  4. Mailbox Flag Replacement: 4 단계, 이미지 1/3 Mailbox Flag Replacement: 4 단계, 이미지 2/3 Mailbox Flag Replacement: 4 단계, 이미지 3/3
    • Push the flag keeper through the bracket until the flag reaches the desired tightness.
  5. Mailbox Flag Replacement: 5 단계, 이미지 1/3 Mailbox Flag Replacement: 5 단계, 이미지 2/3 Mailbox Flag Replacement: 5 단계, 이미지 3/3
    • You are finished! Stand your flag up to ensure it works and is at the desired tightness.
    • If you would like your flag tighter, push the flag keeper in further.
결론
To take the flag off your mailbox, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Ashley Fredricksen
회원 가입일: 09/19/18
184 평판
안내서 1개 작성함
Pasco Hernando, Team S5-G75, Prince Fall 2018 Pasco Hernando, Team S5-G75, Prince Fall 2018 회원
PHSC-PRINCE-F18S5G75
1 회원
안내서 1개 작성하였습니다
댓글 3개
Step 2 is wrong. It shows the bracket being pushed into the wrong side of the flag. If you push it into the flat side, as shown, not enough of the bracket will stick inside the mailbox for the flag keeper to be inserted.
Todd - 답글
so where do I buy the ‘flag keeper” to insert in the bracket?
karen dodd - 답글
Do you have one with 3 holes, maybe an older style?
Donna Mosby - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 73
30일 전: 282
전체 시간: 18,090
