주요 콘텐츠로 건너뛰기
Maisto Rock Crawler Rear Axle Replacement
필요한 것
  1. Maisto Rock Crawler Rear Axle Replacement, Rear Axle: 1 단계, 이미지 1/1
    • Flip the R/C truck over.
    • To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7 mm Phillips screws highlighted.
  2. Maisto Rock Crawler Rear Axle Replacement: 2 단계, 이미지 1/1
    • Half way remove the truck top so you can unhinge the antenna from the clips.
    • Remove the R/C truck top completely.
  3. Maisto Rock Crawler Rear Axle Replacement: 3 단계, 이미지 1/1
    • Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5 mm Phillips screws.
  4. Maisto Rock Crawler Rear Axle Replacement: 4 단계, 이미지 1/1
    • After removing the plate use the driver and bit J1 to unscrew the two 9.5 mm Phillips screws that hold the side circuit board in.
  5. Maisto Rock Crawler Rear Axle Replacement: 5 단계, 이미지 1/1
    • Flip the R/C truck over and remove the four 10 mm bottom under-body plate screws using the driver and bit PH2.
  6. Maisto Rock Crawler Rear Axle Replacement: 6 단계, 이미지 1/1
    • Flip the R/C truck over again.
    • Remember which wire is connected at which pin before desoldering.
    • Desolder the 2 wires connected from the rear axle to the circuit board.
  7. Maisto Rock Crawler Rear Axle Replacement: 7 단계, 이미지 1/1
    • You can refer to the tire replacement guide to keep salvageable tires from the removed axle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
kevin
회원 가입일: 02/10/16
874 평판
안내서 6개 작성하였습니다
USF Tampa, Team 1-2, Sullivan Spring 2016 USF Tampa, Team 1-2, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G2
3 회원들
안내서 6개 작성하였습니다
댓글 2개
Nice guide. Do you know where to buy parts for the repairment? I have searched all over but cannot seem to find any parts.
martinrene - 답글
Your best bet is a hobby shop I haven't seen any online sources myself
kevin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 2,437
