주요 콘텐츠로 건너뛰기
Maisto Rock Crawler Remote Circuit Board Replacement
필요한 것
  1. Maisto Rock Crawler Remote Circuit Board Replacement, Remote Circuit Board: 1 단계, 이미지 1/1
    • Remove the batteries before doing anything.
    • Use the driver and bit J1 to remove the five 9.5mm Philips screws holding the remote together.
  2. Maisto Rock Crawler Remote Circuit Board Replacement: 2 단계, 이미지 1/1
    • Take off the half of the remote that had the screw heads facing up.
  3. Maisto Rock Crawler Remote Circuit Board Replacement: 3 단계, 이미지 1/1
    • Slide out the circuit board.
    • Use the soldering iron to desolder the 3 wires.
결론
다른 5명이 해당 안내서를 완성하였습니다.
kevin
회원 가입일: 02/10/16
874 평판
안내서 6개 작성하였습니다
USF Tampa, Team 1-2, Sullivan Spring 2016 USF Tampa, Team 1-2, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G2
3 회원들
안내서 6개 작성하였습니다
댓글 5개
Can you show the wheel controller mechanism. I can see 3 contacts on mine but I think mine is missing something that would bring the contacts together as you turn the wheel to steer left and right. Thanks.
Ferdinand Fong - 답글
the triger is broken to drive the truck
joey heller - 답글
Somebody have the remote control for
Theodore Brock - 답글
I have a 1970 R/T charger RC car, 2.4GHz, I changed it up fully, but the pairing light wont come on. But I can show the lights,the control power is good.what is wrong can anybody help me find the problem and fix it.
Keith Pryor - 답글
How to pair new controller ?
Karel Říha - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 33
전체 시간: 4,604
