주요 콘텐츠로 건너뛰기
Maisto Rock Crawler Truck Circuit Board Replacement
필요한 것
  1. Maisto Rock Crawler Truck Circuit Board Replacement, Truck Circuit Board: 1 단계, 이미지 1/2 Maisto Rock Crawler Truck Circuit Board Replacement, Truck Circuit Board: 1 단계, 이미지 2/2
    • Flip the R/C truck over.
    • To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7mm Philips screws highlighted.
  2. Maisto Rock Crawler Truck Circuit Board Replacement: 2 단계, 이미지 1/2 Maisto Rock Crawler Truck Circuit Board Replacement: 2 단계, 이미지 2/2
    • Half way remove the truck top so you can unhinge the antenna from the clips.
    • Remove the R/C truck top completely.
  3. Maisto Rock Crawler Truck Circuit Board Replacement: 3 단계, 이미지 1/1
    • Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5mm Philips screws.
  4. Maisto Rock Crawler Truck Circuit Board Replacement: 4 단계, 이미지 1/1
    • Use the driver and bit J1 and remove the 7.7mm Philips screw highlighted.
  5. Maisto Rock Crawler Truck Circuit Board Replacement: 5 단계, 이미지 1/1
    • Take note of which wire is connected at which pin before desoldering. It might help to mark the wires and take a picture.
    • It would be easier to desolder and resolder only one component at a time.
    • Use the soldering iron to desolder all the wires connected to the circuit board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
kevin
회원 가입일: 02/10/16
874 평판
안내서 6개 작성하였습니다
USF Tampa, Team 1-2, Sullivan Spring 2016 USF Tampa, Team 1-2, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G2
3 회원들
안내서 6개 작성하였습니다
댓글 9개
Can you do anything to it to make it stronger are powerful
Matt John - 답글
Yes put a board from a nikko or ez tec in it. The 9.6 volt is the one to find and wire the motors to the single motor output. I think u have to wire one backwards to get both going right way
Mike - 답글
My rc car is not responding to left or right signals from remote.
CAN I got any help on this
pankaj kapatia - 답글
Can any one help as my rc rock crawler is not turning left or right
pankaj kapatia - 답글
did you use biger voltage than normal? because it sound like that. i think your’s car has brokened ic-component.
mattilajanne - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 29
전체 시간: 5,451
