소개
This guide will walk you through the process of replacing the truck circuit board in a Maisto Rock Crawler.
필요한 것
Flip the R/C truck over.
To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7mm Philips screws highlighted.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 9개
My rc car is not responding to left or right signals from remote.
CAN I got any help on this
Can any one help as my rc rock crawler is not turning left or right
did you use biger voltage than normal? because it sound like that. i think your’s car has brokened ic-component.
