주요 콘텐츠로 건너뛰기
Making a low cost photography light stand
필요한 것
  1. Making a low cost photography light stand, Unplug the lamp: 1 단계, 이미지 1/1
    • Before disassembling on the lamp, it MUST be unplugged!
  2. Making a low cost photography light stand, Remove the lightbulb: 2 단계, 이미지 1/3 Making a low cost photography light stand, Remove the lightbulb: 2 단계, 이미지 2/3 Making a low cost photography light stand, Remove the lightbulb: 2 단계, 이미지 3/3
    • If the bulb is worth keeping, this can be reused.
    • If the lamp has a lightbulb installed, remove it from the lamp.
  3. Making a low cost photography light stand, Remove the socket cover: 3 단계, 이미지 1/3 Making a low cost photography light stand, Remove the socket cover: 3 단계, 이미지 2/3 Making a low cost photography light stand, Remove the socket cover: 3 단계, 이미지 3/3
    • MOST LAMPS WILL BE SIMILAR, but designs can vary.
    • Remove the switch handle. Note: While this can be optional, it was required on this lamp. If it looks tied into something, it probably has to be removed.
    • Remove the socket cover. Once removed, remove the bulb socket.
  4. Making a low cost photography light stand, Remove the bulb socket: 4 단계, 이미지 1/2 Making a low cost photography light stand, Remove the bulb socket: 4 단계, 이미지 2/2
    • Sockets that hold the cord in with a press-fit design are hard to reuse by design. Unless you can depress the cord, cut the cord at the socket and discard the bulb socket.
    • After removing the plastic cover and switch, remove the bulb socket with a Phillips #2 screwdriver. If your socket is press fit, these are generally not reusable. Cut the cord unless you can pull the cord and not compromise the socket.
    • Discard any broken or unwanted components.
  5. Making a low cost photography light stand, Remove the cord: 5 단계, 이미지 1/3 Making a low cost photography light stand, Remove the cord: 5 단계, 이미지 2/3 Making a low cost photography light stand, Remove the cord: 5 단계, 이미지 3/3
    • Keep the cord if it is in good shape. These are excellent to keep around to repair other lamps (or anything in need of a similar cord).
    • After removing the bulb socket, remove the power cord.
  6. Making a low cost photography light stand, Test the lamp and find a good clamp point: 6 단계, 이미지 1/1
    • After gutting the lamp, find a good spot to clamp a workshop light on like the one shown. Additional changes like height reduction can also be done at this stage.
결승점
Nick
회원 가입일: 11/10/09
88,987 평판
안내서 50개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,468개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 18
전체 시간: 461
