주요 콘텐츠로 건너뛰기
Making a low cost photography light stand
필요한 것
  1. Making a low cost photography light stand, Unplug the lamp: 1 단계, 이미지 1개 중 1개
    • Before disassembling on the lamp, it MUST be unplugged!
  2. Making a low cost photography light stand, Remove the lightbulb: 2 단계, 이미지 3개 중 1개 Making a low cost photography light stand, Remove the lightbulb: 2 단계, 이미지 3개 중 2개 Making a low cost photography light stand, Remove the lightbulb: 2 단계, 이미지 3개 중 3개
    • If the bulb is worth keeping, this can be reused.
    • If the lamp has a lightbulb installed, remove it from the lamp.
  3. Making a low cost photography light stand, Remove the socket cover: 3 단계, 이미지 3개 중 1개 Making a low cost photography light stand, Remove the socket cover: 3 단계, 이미지 3개 중 2개 Making a low cost photography light stand, Remove the socket cover: 3 단계, 이미지 3개 중 3개
    • MOST LAMPS WILL BE SIMILAR, but designs can vary.
    • Remove the switch handle. Note: While this can be optional, it was required on this lamp. If it looks tied into something, it probably has to be removed.
    • Remove the socket cover. Once removed, remove the bulb socket.
  4. Making a low cost photography light stand, Remove the bulb socket: 4 단계, 이미지 2개 중 1개 Making a low cost photography light stand, Remove the bulb socket: 4 단계, 이미지 2개 중 2개
    • Sockets that hold the cord in with a press-fit design are hard to reuse by design. Unless you can depress the cord, cut the cord at the socket and discard the bulb socket.
    • After removing the plastic cover and switch, remove the bulb socket with a Phillips #2 screwdriver. If your socket is press fit, these are generally not reusable. Cut the cord unless you can pull the cord and not compromise the socket.
    • Discard any broken or unwanted components.
  5. Making a low cost photography light stand, Remove the cord: 5 단계, 이미지 3개 중 1개 Making a low cost photography light stand, Remove the cord: 5 단계, 이미지 3개 중 2개 Making a low cost photography light stand, Remove the cord: 5 단계, 이미지 3개 중 3개
    • Keep the cord if it is in good shape. These are excellent to keep around to repair other lamps (or anything in need of a similar cord).
    • After removing the bulb socket, remove the power cord.
  6. Making a low cost photography light stand, Test the lamp and find a good clamp point: 6 단계, 이미지 1개 중 1개
    • After gutting the lamp, find a good spot to clamp a workshop light on like the one shown. Additional changes like height reduction can also be done at this stage.
결승점
작성자
3다른 기여자 명과 함께
Nick
회원 가입일: 11/10/09
98,270 평판
안내서 62개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 745
