주요 콘텐츠로 건너뛰기
Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement
필요한 것
  1. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the sprocket guard plate: 1 단계, 이미지 1/1
    • Use a 13 mm socket to remove the two nuts securing the sprocket guard plate.
  2. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 2 단계, 이미지 1/1
    • Remove the sprocket guard plate.
  3. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the chain and guide bar: 3 단계, 이미지 1/1
    • If the chainsaw has a chain and guide bar installed, follow the manufacturer's instructions and remove them before proceeding.
    • During reassembly, if you are reinstalling the chain and guide bar, follow the manufacturers instructions on proper chain tensioning techniques.
  4. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the chain brake cover: 4 단계, 이미지 1/1
    • Remove the four 12 mm long T27 screws securing the chain brake cover.
  5. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 5 단계, 이미지 1/1
    • Remove the chain brake cover.
  6. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the tensioner assembly: 6 단계, 이미지 1/1
    • Twist the tension screw clockwise until the slide bar stops at the right end.
    • Remove the single 15.7 mm long T27 screw holding the chain tensioner assembly in place.
  7. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 7 단계, 이미지 1/1
    • Use your fingers to pull the assembly out of its recess and remove it.
  8. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 8 단계, 이미지 1/1
    • If the packing ring did not come out with the assembly, remove it from the recess.
  9. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Assemble the replacement tensioner: 9 단계, 이미지 1/1
    • The next three steps show how to prepare the new tensioning assembly for replacement.
    • Lightly lubricate the packing ring and press it into the back of the adjustment screw.
  10. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 10 단계, 이미지 1/1
    • Slide the adjustment screw into the tensioning assembly such that the gears mesh together.
  11. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 11 단계, 이미지 1/1
    • Slide the shaped plastic bearing onto the end of the assembly.
    • Lightly lubricate all moving surfaces.
  12. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 12 단계, 이미지 1/1
    • Line up the tensioning assembly with its recess in the chainsaw and push it into the recess.
    • Make sure that the black plastic bearing slides in rounded-edge first.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
249,849 평판
안내서 503개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,732개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 21
전체 시간: 2,324
