소개
These instructions will show you how to replace the rear axle of your Makita DLM431 lawn mower.
필요한 것
Remove lock key and the grass-catching basket.
Put the lawnmower on its head and store it safely.
Loosen the nut of the wheels with a 13mm spanner.
Pull the wheel off the axle
Loosen the nut of the connection between rear axle and axle adjustment with the 13mm nut.
Pull off the axle adjustment linkage.
Remove screws with a Phillips screwdriver.
Push the axle holder backwards through the fairing to expose the axle.
Congrats! Now follow the steps in reverse order to reassemble your unit.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
carlotremolada님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
