주요 콘텐츠로 건너뛰기
Makita GA4030K Armature Replacement
필요한 것
  1. Makita GA4030K Armature Replacement, Disk Cover: 1 단계, 이미지 1/1
    • Check for the provided lock nut wrench. This is used for loosening the piece that keeps the disk and cover attached.
  2. Makita GA4030K Armature Replacement: 2 단계, 이미지 1/1
    • Unscrew the handle unit until it is removed completely.
  3. Makita GA4030K Armature Replacement: 3 단계, 이미지 1/2 Makita GA4030K Armature Replacement: 3 단계, 이미지 2/2
    • Hold the black switch located on the front casing.
    • Still holding the switch, use the lock nut wrench to loosen the silver disk holding everything in place.
    • Once loose, remove the silver disk and/or your grinding disk.
  4. Makita GA4030K Armature Replacement: 4 단계, 이미지 1/2 Makita GA4030K Armature Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #02 screwdriver to remove the 15 mm pan head screw that holds the cover in place.
    • Remove the cover by lining up the knob on the cover with the notch in face plate.
  5. Makita GA4030K Armature Replacement, Back Cover: 5 단계, 이미지 1/2 Makita GA4030K Armature Replacement, Back Cover: 5 단계, 이미지 2/2
    • Unscrew the 20 mm tapping screw using a Philips #02 screwdriver.
  6. Makita GA4030K Armature Replacement: 6 단계, 이미지 1/1
    • Slide the back cover down the power cable.
  7. Makita GA4030K Armature Replacement, Armature: 7 단계, 이미지 1/2 Makita GA4030K Armature Replacement, Armature: 7 단계, 이미지 2/2
    • Use a spudger to gently move the brush holder coil to the side.
    • There are two brushes that are secured by two separate brush holders, one on each side.
  8. Makita GA4030K Armature Replacement: 8 단계, 이미지 1/2 Makita GA4030K Armature Replacement: 8 단계, 이미지 2/2
    • Using a metal spudger, remove both carbon brushes (one on each side) by their copper cabling.
  9. Makita GA4030K Armature Replacement: 9 단계, 이미지 1/3 Makita GA4030K Armature Replacement: 9 단계, 이미지 2/3 Makita GA4030K Armature Replacement: 9 단계, 이미지 3/3
    • Use a Phillips #2 screwdriver to remove the four 20 mm tapping screws that hold the armature assembly in place.
    • Remove the armature assembly
  10. Makita GA4030K Armature Replacement: 10 단계, 이미지 1/2 Makita GA4030K Armature Replacement: 10 단계, 이미지 2/2
    • Unscrew the four 10 mm tapping screws holding the faceplate using a Phillips #02 screwdriver.
    • Remove the faceplate.
  11. Makita GA4030K Armature Replacement: 11 단계, 이미지 1/2 Makita GA4030K Armature Replacement: 11 단계, 이미지 2/2
    • Hold the highlighted nut with a size 10 wrench. Unscrew by turning the armature and holding the nut in place.
    • The nut may be difficult to remove.
  12. Makita GA4030K Armature Replacement: 12 단계, 이미지 1/1
    • Remove the armature.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Laura Ann Jagels
회원 가입일: 04/01/15
490 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-5, Lancaster Spring 2015 Cal Poly, Team 12-5, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G5
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 3,386
