소개
Use this guide to replace the power cord in a Makita Jack Hammer HM1203C 2010.
필요한 것
Use a Phillips #2 screwdriver to remove two screws securing the handle cover.
Use a Phillips #2 screwdriver to remove the screw securing the power cord bracket.
이 단계에 사용된 도구:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 2.5 mm flathead screwdriver to loosen the two set screws holding in the power cord wires.
Use 10 gauge wire strippers to strip about 1/8 inch of insulation off of each wire of the new power cord.
다른 2명이 해당 안내서를 완성하였습니다.
