소개
If your battery has issues, this guide will walk you through how to remove it from the Makita XPH01 cordless drill. Step 1 will show how to orient and handle your device, and Steps 2 and 3 show how to detach the battery. This guide requires no tools.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Cordless Drill Battery for Makita XPH01
Type: Li-ion
Volt: 18V
Capacity: 3000mAh
Color: black
Weight: 575.8g
Dimension: 114.80 x 74.55 x 65.20mm
If you interested this battery, please go to view the detail on https://www.drill-battery.net.au/buybatt...
