주요 콘텐츠로 건너뛰기
Makita XPH01 Clutch Leaf Spring Replacement
필요한 것
  1. Makita XPH01 Clutch Leaf Spring Replacement, Battery: 1 단계, 이미지 1/1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Clutch Leaf Spring Replacement: 2 단계, 이미지 1/1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Clutch Leaf Spring Replacement: 3 단계, 이미지 1/1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Clutch Leaf Spring Replacement, Outer Casing: 4 단계, 이미지 1/2 Makita XPH01 Clutch Leaf Spring Replacement, Outer Casing: 4 단계, 이미지 2/2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 Clutch Leaf Spring Replacement: 5 단계, 이미지 1/1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 Clutch Leaf Spring Replacement: 6 단계, 이미지 1/2 Makita XPH01 Clutch Leaf Spring Replacement: 6 단계, 이미지 2/2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 Clutch Leaf Spring Replacement: 7 단계, 이미지 1/2 Makita XPH01 Clutch Leaf Spring Replacement: 7 단계, 이미지 2/2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 Clutch Leaf Spring Replacement, Clutch Leaf Spring: 8 단계, 이미지 1/1
    • Pull the silver metal clip located towards the back of the motor assembly away from the drill.
  9. Makita XPH01 Clutch Leaf Spring Replacement: 9 단계, 이미지 1/2 Makita XPH01 Clutch Leaf Spring Replacement: 9 단계, 이미지 2/2
    • Grip the motor comfortably towards the front of the assembly, and pull it away from the outer casing.
    • The wires are still connected to the back of the motor assembly, so use caution when pulling the motor out. Failing to do this will result in parts falling off the back of the motor.
  10. Makita XPH01 Clutch Leaf Spring Replacement: 10 단계, 이미지 1/2 Makita XPH01 Clutch Leaf Spring Replacement: 10 단계, 이미지 2/2
    • Slide the clutch leaf spring off with the spudger.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Eric Herwatt
회원 가입일: 10/05/16
984 평판
안내서 7개 작성하였습니다
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 21
전체 시간: 2,944
