주요 콘텐츠로 건너뛰기
Makita XPH01 Drill Brush Replacement
필요한 것
  1. Makita XPH01 Drill Brush Replacement, Battery: 1 단계, 이미지 1/1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Drill Brush Replacement: 2 단계, 이미지 1/1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Drill Brush Replacement: 3 단계, 이미지 1/1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Drill Brush Replacement, Drill Brush: 4 단계, 이미지 1/1
    • Hold the drill upright with the back panel facing you.
  5. Makita XPH01 Drill Brush Replacement: 5 단계, 이미지 1/2 Makita XPH01 Drill Brush Replacement: 5 단계, 이미지 2/2
    • Unscrew two 18mm screws from the back panel with the Phillips PH2 screwdriver.
  6. Makita XPH01 Drill Brush Replacement: 6 단계, 이미지 1/2 Makita XPH01 Drill Brush Replacement: 6 단계, 이미지 2/2
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  7. Makita XPH01 Drill Brush Replacement: 7 단계, 이미지 1/3 Makita XPH01 Drill Brush Replacement: 7 단계, 이미지 2/3 Makita XPH01 Drill Brush Replacement: 7 단계, 이미지 3/3
    • Hold the drill so the back end is facing toward you.
    • Use the spudger to lift the spring clip out of the back notch.
    • Pull the spring clip forward and rest it in the front notch.
  8. Makita XPH01 Drill Brush Replacement: 8 단계, 이미지 1/2 Makita XPH01 Drill Brush Replacement: 8 단계, 이미지 2/2
    • Use the tweezers to pull the drill brush away from the sleeve.
  9. Makita XPH01 Drill Brush Replacement: 9 단계, 이미지 1/3 Makita XPH01 Drill Brush Replacement: 9 단계, 이미지 2/3 Makita XPH01 Drill Brush Replacement: 9 단계, 이미지 3/3
    • Use the plastic opening tool to release the clip connected to the drill brush.
    • Separate the drill brush away from the clip.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Eric Herwatt
회원 가입일: 10/05/16
984 평판
안내서 7개 작성하였습니다
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G4
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 5,836
