주요 콘텐츠로 건너뛰기
Makita XPH01 Gear Select Switch Replacement
필요한 것
  1. Makita XPH01 Gear Select Switch Replacement, Outer Casing: 1 단계, 이미지 1/2 Makita XPH01 Gear Select Switch Replacement, Outer Casing: 1 단계, 이미지 2/2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  2. Makita XPH01 Gear Select Switch Replacement: 2 단계, 이미지 1/1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  3. Makita XPH01 Gear Select Switch Replacement: 3 단계, 이미지 1/2 Makita XPH01 Gear Select Switch Replacement: 3 단계, 이미지 2/2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  4. Makita XPH01 Gear Select Switch Replacement: 4 단계, 이미지 1/2 Makita XPH01 Gear Select Switch Replacement: 4 단계, 이미지 2/2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  5. Makita XPH01 Gear Select Switch Replacement, Gear Select Switch: 5 단계, 이미지 1/1
    • Pull the silver metal clip located towards the back of drill away from the motor assembly.
  6. Makita XPH01 Gear Select Switch Replacement: 6 단계, 이미지 1/2 Makita XPH01 Gear Select Switch Replacement: 6 단계, 이미지 2/2
    • Gently grip the front of the motor assembly and pull it out of the plastic casing.
    • The wires are still connected to the back of the motor assembly, so use caution when pulling the motor out. Failing to do this will result in parts falling off the back of the motor
  7. Makita XPH01 Gear Select Switch Replacement: 7 단계, 이미지 1/2 Makita XPH01 Gear Select Switch Replacement: 7 단계, 이미지 2/2
    • Push gear select switch forward.
    • Lift the gear select switch to separate it from the motor assembly.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Eric Herwatt
회원 가입일: 10/05/16
984 평판
안내서 7개 작성하였습니다
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 1,220
