주요 콘텐츠로 건너뛰기
Makita XPH01 LED Light Replacement
필요한 것
  1. Makita XPH01 LED Light Replacement, Battery: 1 단계, 이미지 1/1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 LED Light Replacement: 2 단계, 이미지 1/1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 LED Light Replacement: 3 단계, 이미지 1/1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 LED Light Replacement, Outer Casing: 4 단계, 이미지 1/2 Makita XPH01 LED Light Replacement, Outer Casing: 4 단계, 이미지 2/2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 LED Light Replacement: 5 단계, 이미지 1/1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 LED Light Replacement: 6 단계, 이미지 1/2 Makita XPH01 LED Light Replacement: 6 단계, 이미지 2/2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 LED Light Replacement: 7 단계, 이미지 1/2 Makita XPH01 LED Light Replacement: 7 단계, 이미지 2/2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 LED Light Replacement, LED Light: 8 단계, 이미지 1/2 Makita XPH01 LED Light Replacement, LED Light: 8 단계, 이미지 2/2
    • Use the pointed end of a plastic spudger to push the LED out of the drill.
  9. Makita XPH01 LED Light Replacement: 9 단계, 이미지 1/2 Makita XPH01 LED Light Replacement: 9 단계, 이미지 2/2
    • Use the pointed edge of a spudger to pull out the black and white wires located on the left hand side of the drill.
    • Use the pointed edge of a spudger to pull out the plastic connector.
  10. Makita XPH01 LED Light Replacement: 10 단계, 이미지 1/3 Makita XPH01 LED Light Replacement: 10 단계, 이미지 2/3 Makita XPH01 LED Light Replacement: 10 단계, 이미지 3/3
    • Use the flat end of the spudger to push in the clip on the plastic connector.
    • Pull both sides of the plastic connector apart.
  11. Makita XPH01 LED Light Replacement: 11 단계, 이미지 1/3 Makita XPH01 LED Light Replacement: 11 단계, 이미지 2/3 Makita XPH01 LED Light Replacement: 11 단계, 이미지 3/3
    • Pull the silver metal clip on the motor away from the drill.
  12. Makita XPH01 LED Light Replacement: 12 단계, 이미지 1/1
    • Pull the black trigger assembly away from the drill.
  13. Makita XPH01 LED Light Replacement: 13 단계, 이미지 1/2 Makita XPH01 LED Light Replacement: 13 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to pull out the LED light assembly.
    very nice tutorial !
    King Rump - 답글
결론
다른 2명이 해당 안내서를 완성하였습니다.
Eric Herwatt
회원 가입일: 10/05/16
984 평판
안내서 7개 작성하였습니다
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G4
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Should I do these steps if my drill is under a warranty?
Richard Williams - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 43
전체 시간: 2,476
