주요 콘텐츠로 건너뛰기
Maquet Servo-U O2 Supply Replacement
  1. Maquet Servo-U O2 Supply Replacement, O2 Supply: 1 단계, 이미지 1/1
    • Turn the inspiratory channel lock one quarter of a turn to release.
    • Lift off the inspiratory channel cover.
    • WARNING! The inspiratory channel cover shall be kept in place once maintenance has been performed. Otherwise the gas modules can be affected and deliver the wrong flow.
  2. Maquet Servo-U O2 Supply Replacement: 2 단계, 이미지 1/1
    • Lower the locking catch.
  3. Maquet Servo-U O2 Supply Replacement: 3 단계, 이미지 1/2 Maquet Servo-U O2 Supply Replacement: 3 단계, 이미지 2/2
    • Disconnect the O2 cell connector.
    • Lift and discard the O2 cell with the rubber seal to special waste and/or remove and discard the bacterial filter to hazardous waste.
  4. Maquet Servo-U O2 Supply Replacement: 4 단계, 이미지 1/1
    • Ensure that the new rubber seal is intact, then firmly put in a new bacterial filter.
  5. Maquet Servo-U O2 Supply Replacement: 5 단계, 이미지 1/1
    • Connect the O2 cell connector.
    • Put the O2 cell in position.
    • Close the locking catch.
  6. Maquet Servo-U O2 Supply Replacement: 6 단계, 이미지 1/1
    • Put the inspiratory channel cover in position.
    • Tighten the inspiratory channel lock.
    • Perform a pre-use check stated in Troubleshooting Page.
결승점
Cassandra Aarrestad
회원 가입일: 01/23/20
627 평판
안내서 4개 작성하였습니다
Cal Poly, Team S7-G2, Paton Spring 2020 Cal Poly, Team S7-G2, Paton Spring 2020 회원
CPSU-PATON-S20S7G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 13
30일 전: 37
전체 시간: 1,988
