주요 콘텐츠로 건너뛰기
Marsback Zephyr Pro Fan Replacement
필요한 것
  1. Marsback Zephyr Pro Fan Replacement, Removing Screws: 1 단계, 이미지 1개 중 1개
    • Start by removing the 2 screws on the bottom of the mouse.
    • You can either remove the rear skate and re-adhere it afterwards or use a 9/64" or 3.5mm drill bit to reveal the holes
    • If you opt to drill a hole through the skate, pressing hard in the area will reveal a indentation where the hole lies
  2. Marsback Zephyr Pro Fan Replacement, Freeing the Shell: 2 단계, 이미지 3개 중 1개 Marsback Zephyr Pro Fan Replacement, Freeing the Shell: 2 단계, 이미지 3개 중 2개 Marsback Zephyr Pro Fan Replacement, Freeing the Shell: 2 단계, 이미지 3개 중 3개
    • First, pull the bottom of the shell slightly apart to create clearance
    • Next, wiggle the bottom of the mouse's base left and right while pulling down
    • Once the locking pieces at the top are free, the base of the mouse will be detached from the top shell
    • Do not fully remove the halves until the ribbon cable between them has been disconnected
  3. Marsback Zephyr Pro Fan Replacement, Replacing the Fan: 3 단계, 이미지 3개 중 1개 Marsback Zephyr Pro Fan Replacement, Replacing the Fan: 3 단계, 이미지 3개 중 2개 Marsback Zephyr Pro Fan Replacement, Replacing the Fan: 3 단계, 이미지 3개 중 3개
    • Open the top shell to the right.
    • Optionally disconnect the ribbon cable to give extra working space by pulling up on the ribbon cable connector's locking piece until the ribbon cable can freely slide out.
    • Unscrew the 2 screws holding in the fan and pull the fan connector out. There is no locking mechanism on the fan connector.
    • If the new fan doesn't have the correct DC connector, you may want to salvage the original fan's connector and solder it onto the new fan. If soldering on a connector, ensure the positive (red) side from the fan ends up on the left when the connector is plugged into the mouse.
    • Slide the new fan onto the mounting posts and replace the screws.
    • Reconnect the fan connector. Ensure the positive side (red) of the fan cable is on the left.
    • Reconnect the top shell ribbon cable and press down the locking tab fully before reassembling the mouse.
    • Before reassembling the shell, it may be a good idea to plug in the mouse to ensure the new fan spins and blows in the correct direction (upwards). Testing the DPI adjustment button and color changing scroll wheel will also test that the ribbon cable has been correctly reinstalled.
  4. Marsback Zephyr Pro Fan Replacement, Reassembly Tips: 4 단계, 이미지 2개 중 1개 Marsback Zephyr Pro Fan Replacement, Reassembly Tips: 4 단계, 이미지 2개 중 2개
    • Pulling up gently on the cable can help slide the locking pieces unto place. Pay attention to the seam between the top/bottom shells.
    • Once the seam is flush, the shells are aligned and can be reattached with the screws under the rear skate.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Stephen Smith
회원 가입일: 10/18/21
305 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 237
