주요 콘텐츠로 건너뛰기
Marshall Emberton Battery Replacement
필요한 것
  1. Marshall Emberton Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the rubber casing from the speaker using your nails to peel the cover off.
  2. Marshall Emberton Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Pry out both covers that are on the front and backside of the speaker to reveal the screws to get inside the speaker.
  3. Marshall Emberton Battery Replacement: 3 단계, 이미지 2개 중 1개 Marshall Emberton Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Use a TR9 screwdriver to remove the eight 1.2 cm screws.
    • Use a spudger or opening tool to pry out the speakers.
  4. Marshall Emberton Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Use a TR9 screwdriver to remove the six 1 cm screws that secure the motherboard.
  5. Marshall Emberton Battery Replacement: 5 단계, 이미지 2개 중 1개 Marshall Emberton Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the three wire connectors marked, by firmly tugging on the wire.
  6. Marshall Emberton Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Use TR9 screwdriver to remove the final two 1.2 cm screws that secure the battery.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Asia Baldwin
회원 가입일: 09/26/22
736 평판
안내서 5개를 작성함
CSU Los Angeles, Team 5-1, Adachi Fall 2022 CSU Los Angeles, Team 5-1, Adachi Fall 2022 회원
CSULA-ADACHI-F22S5G1
5 회원들
안내서 6개를 작성함
5가이드 댓글
Add any tools at the top you used in this repair guide and also any replacement parts if you can.
Yamilena Hernandez - 답글
How can i buy battery
Rubel hussain - 답글
How can I buy the battery
Sreenath Ps - 답글
How to buy a battery for my emberton?
MADHANRAJ MURUGESAN - 답글
From where to buy battery? What is the battery specification?
Hasin Shahriar - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 83
지난 30일: 418
전체 시간: 16,583
