주요 콘텐츠로 건너뛰기
Marshall Emberton Button Replacement
필요한 것
  1. Marshall Emberton Button Replacement, Button: 1 단계, 이미지 1개 중 1개
    • Remove the rubber casing from the speaker by peeling it off using your nails.
  2. Marshall Emberton Button Replacement: 2 단계, 이미지 1개 중 1개
    • Use a TR9 screwdriver to remove the eight 1 cm screws located on top of the speaker.
  3. Marshall Emberton Button Replacement: 3 단계, 이미지 1개 중 1개
    • Once all the screws are off, you must pry the plastic piece off using any tool capable of sliding into the crevice. Then easily pop the piece out.
  4. Marshall Emberton Button Replacement: 4 단계, 이미지 1개 중 1개
    • On the back side of the plastic piece, there is a circuit which is shown in the picture. Use a TR9 screwdriver to remove two 1.2 cm screws to detach the circuit from the plastic housing.
  5. Marshall Emberton Button Replacement: 5 단계, 이미지 1개 중 1개
    • Once the circuit is removed, you may gently pop the button off and easily replace it with a new one.
결론
작성자
4다른 기여자 명과 함께
Asia Baldwin
회원 가입일: 09/26/22
736 평판
안내서 5개를 작성함
CSU Los Angeles, Team 5-1, Adachi Fall 2022 CSU Los Angeles, Team 5-1, Adachi Fall 2022 회원
CSULA-ADACHI-F22S5G1
5 회원들
안내서 6개를 작성함
3가이드 댓글
where can i find a replacement button
MANU 1907 - 답글
The worst instruction I've ever seen in my life. If you do this, you will break your device.
cool eo - 답글
yes, i confirme !!!
Mallet Jp -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 118
전체 시간: 3,198
